Belkin Omniview pro 3 KVM switch
Sell your QL items here!
I'm selling one of my KVM switches - this is a model F1DA108Z USB and PS2 KVM switch
https://www.belkin.com/pro3-8-port-kvm- ... A108Z.html
It has a console port that can either take PS/2 Keyboard and Mouse OR USB keyboard and mouse including some wireless models and can connect to servers using either PS/2 or USB - I believe all the servers have to have the same connectivity - so all PS/2 or all USB - but they can be different from the console port devices.
This works beautifully with the Q68 and supports the extended mouse features.
Selection of the 8 servers can be made with a front panel switch or a key sequence from the console keyboard or from the full on screen display. The Server ports can be named for clarity during switching operations.
I will supply one dual set of PS/2 +VGA leads - 10ft long - so you have a cable for your first 2 devices - the cables are easy to obtain. Also I will include a suitable power supply for the KVM unit.
Firmware has been upgraded to the latest 1V5 and I will include a set of 19" rack mounting brackets.
You can also daisy chain these units for more ports too - upto 16 units I believe.
The item is used and has some scratches on the top of the unit. I am looking for £75 or sensible offers
