Defects in video output.
ludekst
Post by ludekst »
Hello.
What can be the cause of defects in the image? RGB2HDMI output.
Thanks
video_output.zip
Video screen
(5.71 MiB) Downloaded 139 times
Re: Defects in video output.
Oh dear, it looks like a glitch in the Matrix.
Cristian
Post by Cristian »
except the video defect, does the QL work normally/properly?
You are using an upscaler: some of them may have problems with QL video output. I suggest to try to connect the QL to a TV (via RGB-SCART or via antenna cable) and check if you see the same defect.
Have you tried also without memory expansion?
ludekst wrote: Tue Jan 03, 2023 8:31 am Hello.
Thanks
Hi
Try changing the setting in the control panel of the RGB2HDMI
If this doe snot work, try looking a Stardot.org where the designers usually is available to help with the problem.
jobdone
Post by jobdone »
Did you ever solve this issue? I remember when first building one of these I had noise on the screen too caused by the PSU (a cheap phone charger), I changed the PSU and the issue disappeared. I would suspect the CPLD though as it is fairly constant.
