QMAC
- XorA
- Site Admin
QMAC
So for a lot of cross compile development the thing we are missing on the host side is a qmac compatible assembler.
I am assuming this was written in assembler and we don't have high level source code for it?
Re: QMAC
Quanta must have had the sources at one point in time, as they were able to develop some useful extensions.XorA wrote:So for a lot of cross compile development the thing we are missing on the host side is a qmac compatible assembler.
There is a cross assembler that can produce QDOS reloctable _rel files as part of the XTC68 cross-compiler, I think.
- mk79
Re: QMAC
I'd be happy if there was at least the assembler codeXorA wrote:So for a lot of cross compile development the thing we are missing on the host side is a qmac compatible assembler.
- XorA
- Site Admin
Re: QMAC
Yeah but assembler seems to be your primary languagemk79 wrote:I'd be happy if there was at least the assembler codeXorA wrote:So for a lot of cross compile development the thing we are missing on the host side is a qmac compatible assembler.
(although I could work with it, Im just really out of practice)
- XorA
- Site Admin
Re: QMAC
I think you are missing the point, getting AN assembler isnt hard, one that understands QMAC macros is harder!Derek_Stewart wrote:Hi
What about: vasm and vlink, they have source available.
Re: QMAC
Sorry.
But I doubt you will get a Qmac comptiable assembler.
My point was there maube a C/C++ based 68K sssembler with macro facities, so is just a matter of writing the Qmac Macros.
- NormanDunbar
- Forum Moderator
Re: QMAC
Never having used macros in QMAC or otherwise, I'm wondering if George Gwilt's GWASS (for 68020) or GWASL (for 68008) assemblers are any use? George's downloads page (http://gwiltprogs.info/page2.htm) mentions that both are macro assemblers and the source code is available. They are both coded in assembler. (Although I don't know at which point George had a good enough assembler to be able to assemble itself!)XorA wrote:There is, and also gas from qdos-gcc but that means unmangling the macros.
With all due respect to George, he does write quite cryptic code as he uses the shortest label names possible!
GWASL: http://gwiltprogs.info/gwasls08.zip
GWASS: http://gwiltprogs.info/gwasss22.zip
- XorA
- Site Admin
Re: QMAC
If people were wondering what i was playing at.
https://github.com/xXorAa/minerva
But it turns out I don't actually need to cross compile, make on QDOS is actually pretty nice.
Now its as simple to build as
ex make
