How do I open this? I can see it is assembler code but because it is a doc extension all the lines are muddled up.dilwyn wrote: http://www.dilwyn.me.uk/qlrom/ipc8049.zip
file problem
file problem
Re: file problem
Here is a quick Quill export in text (verbatim).
BTW it is attributed to Laurence Reeves but IMHO it isn't. I think it is JV (known early QL'er)
- ipc8049txt.zip
- (17.04 KiB) Downloaded 104 times
David
Re: file problem
Thanks man, I am not geared up to convert files yet. The header says "JV 970715" that points to JV as you said.Silvester wrote:Here is a quick Quill export in text (verbatim).BTW it is attributed to Laurence Reeves but IMHO it isn't. I think it is JV (known early QL'er)
