Non blocking keyboard in curses
I have been working on a curses driven program and I am hitting the problem that keyboard input is always blocking.
Probably something simple I have missed about QL.
raw() - is set
nodelay() - is set
wgetch() is still blocking though when docs say it should not be.
Re: Non blocking keyboard in curses
I seem to distantly recall that a small (1 tick) delay worked better on the QL than nodelay().
tofro wrote:I seem to distantly recall that a small (1 tick) delay worked better on the QL than nodelay().
I’ll give that a go!
Confirmed halfdelay(1) works as effectively non blocking thanks!
