Does anyone know where I can buy a QL replacement PSU?
I'm not looking for the original, but something more modern.
Thanks.
QL PSU
Re: QL PSU
The only commercially available (sometimes) one is this from Charles Ingley in NZ:
https://www.tindie.com/products/charlie ... sal-input/
Don't know when he's doing a new batch but I do know that he's not sending to the UK at the moment
Re: QL PSU
Thanks, that seems what I'm looking for. It doesn't say out of stock, so I assume he has some?
The only thing missing seems to be the cable that goes to the outlet.
Re: QL PSU
You need a separate 12v PSU to feed it and it then takes care of the rest. Are you in the UK, are you able to order one from Tindie? If not, I may be able to help from here.
