Q: SuperBASIC net driver semantics
ppe
Post by ppe »
Hello everyone,
I would appreciate some feedback and ideas from SuperBASIC programmers. I'm continuing work on my W5300 based ethernet card driver for a black box QL. The driver currently supports TCP_ channels and SuperBASIC OPEN, CLOSE, PRINT, INKEY$ and INPUT keywords. Syntax of the driver string is currently "TCP_<host>:<port>". This is enough for most TCP client software, and in fact Tim and Dilwyn's SuperBASIC IRC client runs nicely already (also when QLiberated). I'm currently in the process of adding UDP support so that e.g. NTP client is easy to write in SuperBASIC.
Next thing on my to-implement list is socket listen functionality. This will enable QL-to-QL communications, or some simple server software (e.g. HTTP shoutbox) to be implemented easily.
I would appreciate some insight on what would be a semantically coherent approach to defining a listening TCP socket from SuperBASIC. For listening, the remote host is obviously not required, but the port on which the socket should listen must be specified. Some approaches I have considered so far:
OPEN #chan,"TCP_:<listen-port>"
The missing host part would imply a listening socket
OPEN #channel,"TCP_":SOCK_LISTEN (#channel,port)
An open without any host:port specification would open a channel and a separate new SOCK_LISTEN keyword would set it in listen mode and specify the port
OPEN "TCPL_<port>"
A separate device identifier for listening sockets
I would really appreciate if you could take a minute to consider what would be the most "SuperBASIC-y" way of doing this. Feedback and opinions on changes / new approaches is welcome.
Kind regards,
Petri
Re: Q: SuperBASIC net driver semantics
Petri,
I don't think it's enough to look at a "SuperBASIC"y implementation. It makes sense to look into other languages (most importantly, C, as this already has a socket implementation).
the original QL (uqlx) socket implementation used the access key in the open call to denote you want to open a server socket. IO_NEW (2) as in "Open new (exclusive) File" was intended to be used for server sockets that are not used for data transfer, but rather only for accept()ing connections. That boils down to using the S*BASIC keyword OPEN_NEW for such sockets, host and port # would then denote the port to listen to. (translated into UNIX terminology, an OPEN_NEW of a TCP socket with a port number only (or your own IP address, or an IP address of 0.0.0.0) covers both the socket() and the bind() system call).
accept() is implemented via IO.OPEN as well, and here is where things are getting a bit wierd in the uqlx implementation: You are expected to open a generic socket ("SCK_") and pass in the accepting socket's channel ID in the access key register (d3, normally used for NEW, OVERWRITE, SHARED, DIRECTORY,.... but obviously with much higher values here). That is obviously not possible from standard S*BASIC, so would need a new implementation. The open call would then return the new socket channel. (That's exactly how the C68 socket implementation talks to the uqlx network driver).
According to the docs its SCK_
ppe
Post by ppe »
Thank you tofro, this is very helpful! Yes, I'm hoping to support the C socket library at one point but tackling SuperBASIC first whilst keeping the library compatibility on the device drvier layer in mind. OPEN_NEW semantics sounds straightforward enough. Being compatible with uqlx semantics is definitely desirable.
So, using the Open Type Key solves half of the problem and then I just need to create a new function
new_chan = SOCK_ACCEPT(#chan)
This would make it easy to use from S*BASIC. And using QLiberator one could then spawn a job per sock_accept to handle the per-client communications.
You might want to check out IP_Basic, here http://www.dilwyn.me.uk/internet/index.html It adds a bunch of SuperBASIC commands like IP_BIND, IP_LISTEN and IP_ACCEPT. The source code is supplied, so you may be able to bend it to do what you want.
I have a later unreleased version than the one on Dilwyn's site. Mostly bug fixes.
ppe
Post by ppe »
Martin_Head wrote:You might want to check out IP_Basic, here http://www.dilwyn.me.uk/internet/index.html It adds a bunch of SuperBASIC commands like IP_BIND, IP_LISTEN and IP_ACCEPT. The source code is supplied, so you may be able to bend it to do what you want.
Thank you Martin for bringing this to my attention, good thing there may be no need to reinvent the wheel! I have no idea how I missed that package on Dilwyn's site... I'll take a look - will probably be interested in the later version, too... :)
Cheers!
Petri
Cheers!
Petri
Here's an unreleased update to IPBasic (Version 1.05)
In the summer of 2019 I did some bug fixes, and liaised with the emulator writers to fix some bugs and inconsistences in their implementations of the IP device driver.
I had been sitting on this update waiting for the emulator writers to release updates. So I could test it, and finish the documentation.
However I started working on the Q68 Ethernet driver, and I have not had the time to test and finish the update.
So you may find some problems.
I have also included an unfinished copy of my QDOS TCP/IP booklet, which I was doing at the same time as it tied into the fixes the Emulator writers were doing.
QDOS TCP 2019_09_27.zip
(56.09 KiB) Downloaded 85 times
IPBasic105.zip
(79.96 KiB) Downloaded 90 times
ppe
Post by ppe »
Martin_Head wrote: Here's an unreleased update to IPBasic (Version 1.05)
Many thanks Martin, very kind of you! And amazing work on the documentation, by the way!
