SMSQ/2 on Atari
Re: SMSQ/2 on Atari
The Indroduction Zip is empty!
Re: SMSQ/2 on Atari
RalfR wrote: Thu Mar 28, 2024 8:47 pm The Indroduction Zip is empty!
I downloaded it, there is a RTF file.
Re: SMSQ/2 on Atari
I see, just haven't saved the ZIP. Earlier Windows versions have done that and opened the ZIP automatically :(
Re: SMSQ/E on Atari
I miss the "SMSQE.PRG" for Atari on W.Lenerz' SMSQ/E site. No longer there or no longer supported? There ist just the QXL.zip.
desin
Brittle Membrane
Re: SMSQ/2 on Atari
Post by desin »
https://www.wlenerz.com/smsqe/
greetings from Switzerland
Markus
Re: SMSQ/2 on Atari
Hi Ralf,
I assume that you visit: https://www.wlenerz.com/smsqe/
and the compiled SMSQ/E binary fileSare downloaded from:https://www.wlenerz.com/smsqe/341/smsqe341_binaries.zip
I downloaded the above file, which contains, SMSQE.PRG whichmis the Atari SMSQ/E
...looks like I am so slow, desin has the finger on the pulse.
Re: SMSQ/2 on Atari
Thank you both Markus & Derek. I remember (maybe wrong) that it was separate in the list.
Re: SMSQ/2 on Atari
HI Ralf,
Do you use an Atari with SMSQ/E?
Re: SMSQ/2 on Atari
Hi Derek,
not recently. I still have my TT somewhere in the cellar and plan to unpack it again. I also have my QVME with an adapter in my self-built MegaST4 "Tower" with an "hyperCACHE" 68030 accelerator board (from proVME).
The "Tower" has worked perfectly 20 years ago (except that the 20MB Rodime hard drive crashed a few times and the TAR backup from JH gave ONE disk error of 30 disks....all lost), but I fear, I should not switch it on in these days.... :D
I also have an "Extended Mode 4" emulator card lying around in a box somewhere, no longer used when I have got the QVME.
Re: SMSQ/2 on Atari
Hi Ralf
I used to use an Mode 8 Emulator on a STFM, with T28 accelerator, and 4Mb Ram expansion, ASCI hard Drive It ran very fast. I was my main machine till the QXL arrived.
Also got a TT but do not use it too much
