Minerva 1.98 vs 1.89 bug
I am seeing a strange bug on uQLx/sQLux where behaviour is different between Minerva 1.89 and 1.98
10 NEW
Run the code above on Minerva 1.98 and it will break the basic tokeniser. If you then for example do
10 PRINT "Hello Forum"
on running you will get a "bad name" error.
On 1.89 it will work as expected.
Does this problem only exist on uQlx based emulators or is it general issue.
BackToQL
Re: Minerve 1.98 vs 1.89 bug
Post by BackToQL »
I get the same problem on my BBQL running Minerve 1.98. To overcome this I need to reset the QL.
Why would you want to put NEW in a programme?
Derek_Stewart wrote:Hi,
No reason I can think of, but it would appear my typo exposed a bug.
BackToQL wrote:I get the same problem on my BBQL running Minerve 1.98. To overcome this I need to reset the QL.
Thanks for checking that, that is the behaviour I see in the emulator too!
