easycap usb 2.0
mhanias
Brittle Membrane
easycap usb 2.0
Post by mhanias »
Did anyone try to get composite signal from QL in easy cap usb 2 video grabber?
Re: easycap usb 2.0
mhanias wrote:Did anyone try to get composite signal from QL in easy cap usb 2 video grabber?
How good is that. I use KWorld USB stick which has composite in (along with digital TV tuner) and the picture it grabs is not the greatest, lost of noise (I can share a video if you like). My LCD TV shows less interference than it. Even when I put the QL into monochrome mode, the USB stick makes it look fuzzy, soft and unfocused whereas my LCD TV makes it look like one of the early b&w kindle readers with the image just standing out.
Also, the stick does what many other video capture cards of the past did, it writes directly to the screen so you can only capture with their software.
