ProPascal INPUTs
stevepoole
ProPascal INPUTs
Post by stevepoole »
Hi All,
After transcoding a dozen or so SuperBasic programs into ProPascal, I am now feeling much more at ease with the latter language.
I can error-trap character and integer input, but not string-type...
The main difficulty is to trap the dreaded null entry !
Has anyone overcome this hurdle ?
Steve.
Re: ProPascal INPUTs
Why not simply check the string that was input for a "Length()" of 0?
valid := FALSE;
REPEAT
	ReadLn (Input, inputLine)
	valid := (Length (inputLine) > 0);
UNTIL valid;
stevepoole
Hi Tofro,
Many thanks. Yes, your solution does work for strings.
I still can't see any way to avoid people entering a null string when an integer or real value is requested...
If ProPascal had a 'power' function, I could do it by adding powers of ten, but there is none...
Do Pascal programmers need to write their own libraries of core routines ?
Best Wishes,
Steve.
stevepoole wrote: Do Pascal programmers need to write their own libraries of core routines ?
Well, all Programmers in all languages that intend to lift their programs from fool-proof to (somewhat) damn-fool-proof, will generally only allow string input - then, in the program, see if this can be converted safely to a number if they actually want one.
Norm's second law of computing:
Whenever you write fool proof code, the universe invents a bigger fool!
Norm's first law, for those wondering:
The complexity of programs doubles every 18 months thus negating all the benefits of Moore's Law.
NormanDunbar wrote:Norm's second law of computing:
I'm with you on that, that's the reason for the somewhat damn-fool-proof.
:D :D :D
stevepoole
Hi Guys,
Without going into details, Propascal string 'lengths' are no good for dealing with numeric inputs.
Propascal arrays are not much use either...
After a lot of experimenting, I finally had to resort to using Tofro's INKEY function to construct my own integer INPUT routine.
Programs are now watertight, but ProPascal is far from being as easy to prototype with as QL Basics !
Many thanks again for the INKEY snippets.
Steve.
