I plan to mount the Q68 into a real QL case, therefore I alredy ordered 2 important things to be able to do that : a PS/2 to USB converter and a QL USB keyboard adapter.
the USB keyboard adapter is this one :
https://www.tindie.com/products/tynemou ... rsion-kit/
and the PS/2 to USB converter is this one :
https://www.black-box.ch/chf-ch/fi/1449 ... 2-vers-USB
it's a bit expensive, but I'm pleased to say that this combinaison work well, the QL keyboard is recognised by the Q68, and the mapping looks correct to me.
I will post some pictures when I did the mod.
In between, I have to questions : When I boot QL/E, It take forever to load the desktop wallpaper (there is a message in the center of the screen telling "Photon-heron-1024x768.jpg" for almost 1 minute) then it takes once again forever to load a QL family picture (one minute too). It is normal? If yes, how can I prevent both images to load, to gain some time?
I tried then to load black phoenix, looks good, but I fail to understand how to change the resolution. Editing the parameters with F2 at boot lead to a error each time I click on someting, and if I issue the command "disp_mode 4" the screen change resolution but goes to the basic prompt, and nothing more happens.
sorry for my dumb questions anyways
