QL speaker
FrancoisLanciault
QL speaker
Post by FrancoisLanciault »
I got a QL with a missing speaker. Anybody can point me to a electrically compatible one ? I don’t care if the size is different, as long as it produce sound! Beside impedance, anything else I need to know ?
Thank you
François
Cristian
Re: QL speaker
Post by Cristian »
I'm not sure, anyway I suppose you should try some like this:
https://www.ebay.it/itm/5V-Piezo-Sounde ... 4&LH_BIN=1
probably they are the same installed in PC motherboards
Re: QL speaker
I found it...should ask the eBayer to return it maybe :D
https://www.ebay.com/itm/ORIGINAL-SINCL ... 1732550898
Re: QL speaker
bwinkel67 wrote:I found it...should ask the eBayer to return it maybe :D
That rascal!
FrancoisLanciault
Re: QL speaker
Anything special about this seller ?
Re: QL speaker
I've bought a few things from him (top and bottom QL case). He seems to sell them in parts. Arrived quickly and as advertised. I had a good experience.
Re: QL speaker
a regular QL breaker !
I had an issue 7 board from him which is now housed in a case that contained a somewhat broken and heavily modded (internal ram upgrade -several dead chips, broken tracks, failed ic's). The issue 7 board is working great :-)
Re: QL speaker
I have some spare QL speakers if anyone needs one
mlasham
Re: QL speaker
Post by mlasham »
RWAP wrote:I have some spare QL speakers if anyone needs one
I need one, just spent the afternoon fixing the reset switch after taking the system board out to clean the case and investigate why I get no sound.
Im guessing the speaker is dead, not sure how to test though
Re: QL speaker
I too am not sure how to test one! Send me a pm with your email address and whereabouts in the world you are and I will send a paypal invoice for the postage
