String + Numbers .... help!
genetika
Post by genetika »
Hi.
I need to convert this BBC BASIC lines in SuperBASIC....
LET E=10
LET TIME=50
PRINT "Line:"+STR$(E)+" X "+STR$(TIME)
I would like to obtain this output="Line:10 X 50"
HELP!
:P
Re: String + Numbers .... help!
genetika wrote:Hi.
LET E=10
LET TIME=50
HELP!
:P
That's actually pretty simple in SuperBASIC:
PRINT "Line:" & E & " X " & TIME
That works because S*BASIC does what's called "coercion" (that is, type conversion) between strings and numbers when needed. S*BASIC sees we want to build a string and converts the numbers into ASCII. That works, BTW, also the other way round:
a$ = "10" : PRINT 1 + a$
will print "11"
polka
Post by polka »
Actually, it is not so simple :
Let's try :
A = 60000000
PRINT#2,A
The QL will answer (on device #2) :
6E7
If you want him to print
60000000
you have to code this little procedure :
1 DEFine PROCedure IP(device,precision,value)
2    f$=""
3    FOR i = 1 to precision
4       f$ = f$ & "#"
5    END FOR i
6    PRINT_USING#device,f$,value
7 END DEFine IP
and tell the QL :
IP(2,8,A)
(2 is the number of the device on which you want the output, and 8 is the number of characters you want to print)
Coercion etc. is "nice", but it lets the QL do what he wants, not what you want.
POLKa
May the FORTH be with you !
POLKa
Right - If you want to have control of the format, you can't use automagic coercion.
But I'm pretty sure the BBC Basic version above would have reverted to exponential notation as well - with such big numbers (The example doesn't seem to use numbers in that range)
polka
Post by polka »
I stumbled on this problem recently, as I was trying to code a simple model for an epidemy propagating in a population of 60000000. This number was too large for using QL integers (limited to 32767), and when using floats, the QL would not format the output to my will. :mrgreen:
Of course, I should have programmed it in Forth, that has only integers but up to 32 bits ; but I was lazy :oops:
POLKa
POLKa
Giorgio Garabello
Post by Giorgio Garabello »
polka wrote:Actually, it is not so simple :
Let's try :
A = 60000000
PRINT#2,A
6E7
60000000
2    f$=""
4       f$ = f$ & "#"
5    END FOR i
7 END DEFine IP
and tell the QL :
IP(2,8,A)
POLKa
Try this: https://superbasic-manual.readthedocs.i ... ht=fdec%24
