So I bought some QL scrap
I got this bundle of bits on ebay for a price that was too tempting not too. Both are listed as broken with the complete one sold as "WHEN PLUGGED INTO THE TV IT JUST COMES UP WITH A PINK RECTANGLE AT THE BOTTOM OF THE SCREEN WHICH IT HAS A FURTHER FAULT" I havn't tried it plugged in yet but I noticed one ROM is a JS and the other is a JM. I didn't think you could mix them? On the other one the PSU socket has come loose.
I didn't realise how filty they were too, probably not a good idea to photo them on my bed. Erk!
Re: So I bought some QL scrap
That's not scrap by any means.
I see a lot of good components and donor parts there that can keep other QLs going...
Yeah :geek:
I doubt that using one JM ROM chip and one JS ROM chip in the same QL would work, so that would be the first thing to sort out.
A good clean of the microdrive units may provide some working units if nothing else.
robheaton
Post by robheaton »
Nice Ebay find there!
Are you planning to create more custom colour QLs?
Your white one is awesome!
vanpeebles wrote:I didn't realise how filty they were too, probably not a good idea to photo them on my bed. Erk!
Can't resist the temptation to say "So that's your idea of a 'dirty weekend' in the vanpeebles household"
Dilwyn
Hehehehe :oops:
Well the cases are all cleaned and I'm about to have a go at trying to get a working one sorted. I'll swop the roms first. Is the tv modulator needed on a QL? I know with the spectrum +3 it's a popular mod to remove them as they generate a lot of noise onto the main board.
Mr_Navigator
QL Fanatic
Post by Mr_Navigator »
I would remove it if not too fiddly, however I have seen the mod that links the composite into the modulator straight out to the phono socket allowing connection to a monitor/tv with composite video in.
I think the supply to the circuit was cut also so power was reduced and noise not generated as you say.
Mr_Navigator
QL Fanatic
BTW what did you clean the QL with?
I need to do this to a couple of mine for piccy taking as too many marks, dirt and dust show up too much.
Hey my 200th post :D
How many 200'ers are there? :?:
