Power supply for QL
Jack_Free
Power supply for QL
Post by Jack_Free »
Hello,
I'm looking for a QL-friendly power supply, including the end cap.
Alternatively, some idea of how to make this resource from the new components.
Thank you
Jack
Sinclair QL + SGC, Sinclair QL+QL-SD.
Excuse my English, I use google translator :-)
drdivago
Re: Power supply for QL
Post by drdivago »
Hi Jack,
FYI I'm currently investigating into assembling two PSUs to power a QL, similar to an object which is currently on offer on eBay by a French guy https://www.ebay.co.uk/itm/Alimentation ... rk:19:pf:0.
Ciao
Leo
Sinclair ZX81, ZX Spectrum, QL: a passion since 1981 :)
That looks truly awful.
If you are comfortable soldering and identifying components, you can use a small PC power supply, remove the 12v regulator (IC37), -12V regulator (IC36) and 7805 (IC35), and solder a mini-ATX PSU outputs to the holes directly. It would cost about the same, and be a whole lot safer.
If you'd like more detailed instructions, I'd just need to know if you have an Issue 5 or Issue 6/7 PCB.
Jack_Free
Post by Jack_Free »
that's really terrible, I might be afraid to join QL
drdivago
Post by drdivago »
Together with a friend we are looking at using the concept of using two PSUs to replicate the original outputs rather than the execution above (I agree it looks unstable and possibly dangerous...)
On the other hand I would like not to touch the QL board if possible, even if those changes are easily undoable.
Thanks
Ciao
Leo
Jack_Free
Post by Jack_Free »
In any case, let me know how you are going.
A certain solution may be.
Would not it be wiser to use only trafo?
So how is it in the original PSU?
Jack_Free wrote:In any case, let me know how you are going.
Designing a PSU that is going to be sold is a tricky business. There's a lot of regulations and certifications, and with power supplies they are not optional. You cannot self certify. The consequences of getting it wrong can be disastrous with people losing their homes or loved ones. That's why I won't do a power supply.
While it would be quite easy to do a copy of Sinclair's design, it simply isn't a very good system. Sure, it was cheap to make and it's held up REALLY well over 35 years. However, it is over-complicated, and it also forced design decisions onto the QL that just don't need to be made these days.
There's other ways to solve this problem.
Jack_Free wrote:Hello,
Thank you
Jack
Hi Jack,
I have QL Power Supply, with a UK mains plug attached.
Price £10 plus postage
Send me a PM if you are interested.
Jack_Free
Post by Jack_Free »
Thank you all for your help, I seem to have found out.
You can close the topic.
Thank you
drdivago
Post by drdivago »
For those still looking for an original QL PSU, there is one on offer right now in eBay: https://www.ebay.co.uk/itm/sinclair-Ql- ... 3757061075
Thanks
Ciao
Leo
