UNZIP problem
UNZIP problem
Hello,
I'm a newbie and I have a problem with UNZIP.
When unzipping any ZIP archive directly on QL, this error returns to me as shown in the picture.
I use UNZIP 5.32.
Command write EW win1_unzip; "-d win1_unzip_ -j win1_program_zip"
Thank you for the advice.
Jack
I use UNZIP 5.32.
Jack
Sinclair QL + SGC, Sinclair QL+QL-SD.
Excuse my English, I use google translator
- NormanDunbar
- Forum Moderator
Re: UNZIP problem
64 bytes missing could mean a missing QDOS file header, perhaps?
However,
Where did the file come from? A PC? Off the internet? Etc. It could be relevant, so please give as much info as possible, thanks.
However,
Re: UNZIP problem
Thank you very much.
Excuse my English, translates Google.
I use the Qubide interface for Sinclair QL
For example, download files here: http://www.dilwyn.me.uk/games/index.html
I'm going to be a file camel.
With the Habi editor (http://hardware.speccy.org/temp/qubide4-i.html), I save the ZIP file to the card.
The program can not be opened.
Jack
EDIT:
You were right, there really is a problem in the header.
I saved the zip file from the QL header and the file is expanded.
I'm glad it works
Jack
EDIT:
I'm glad it works
Re: UNZIP problem
I've just checked the zip file on the website by downloading and unzipping. I can confirm that the zip file itself is OK - the program executes normally.
I'm afraid I don't have knowledge of the Habi image editor for Qubide to know what issues there might be when using that.
Re: UNZIP problem
The Habi editor has a checkbox "Options"->"Headers"->"Extract"
I'm pretty sure both "Extract" and "QL" need to be checked when moving a file from the PC to the QL file system and unchecked when transferring the other way round.
You should play with these settings, it looks like you have these wrong.
Re: UNZIP problem
Yes it is, the problem is in the setup.
When saving files to a card, it is necessary to tick OPTION - HEADERS - QL even if ZIP files are saved.
I have used this option only for BAS files
And they were functional.
I saved the _ZIP files without a QL header, and that was the problem.
- NormanDunbar
- Forum Moderator
Re: UNZIP problem
Glad you were able to work it out.
Re: UNZIP problem
Hello.
I have a QL with a Tetroid (disc controller + 780k memory), and have problems using the -d option.
Whenever I write something like
or
I get the "xxx not found" (or something like that where xxx is ram2_ or flp2_).
What is wrong with my unzip usage ?
EW ram1_unzip; "-d ram2_ flp1_program_zip"
EW ram1_unzip; "-d flp2_ flp1_program_zip"
Re: UNZIP problem
I have just tried the command on QPC2, that works. I use Unzip version 5.32
I'm assuming that the copy of Unzip is really in ram1_ and the zip file is also where the command says it is. Hopefully, the zip file has a '_' before the extension, not a '.'
On some systems, there should be no space between -d and the drive name, but on my QPC2 setup, it seems to work with either -dram1_ or -d ram1_
Can also be tested by using a pair of commands such as
DATA_USE ram1_ : EW ram1_unzip;"flp1_program_zip"
Re: UNZIP problem
Looks like your version of unzip may need the commands the other way round, ie not
but
EW ram1_unzip; "flp1_program_zip -d flp2_ "
