Anyone know if it's possible to test for whether the system a program is running on supports level 2 directories?
I'm sure I've read the answer somewhere before but can't for the life of me remember where.
Level 2 check
- NormanDunbar
- Forum Moderator
Re: Level 2 check
Head over to Dilwyn's web site and download DJToolkit. It has a function called, level2, which does exactly what you want.
HTH
HTH
Re: Level 2 check
Many thanks.NormanDunbar wrote:Head over to Dilwyn's web site and download DJToolkit. It has a function called, level2, which does exactly what you want.
HTH
David
- NormanDunbar
- Forum Moderator
Re: Level 2 check
Sorry, forgot the link http://www.dilwyn.me.uk/tk/djtk.zip and the keyword you want is at https://superbasic-manual.readthedocs.i ... evel2.html.
Cheers.
Cheers.
Re: Level 2 check
You could probably test for the presence of the MAKE_DIR extension, but I seem to recall that QemuLator can't create directories in QXL.WINs for example.
A while back I lifted the code for the LEVEL2 extension out of Norman Dunbar's DJToolkit and made a stand-alone extension function out of it, called LEVEL2% to avoid a clash of names with Norman's extension.
I'll upload it to my site in a minute in case others can make use of it, meanwhile here's a copy to test if it does what you want. Hope you don't mind, Norman?
- NormanDunbar
- Forum Moderator
Re: Level 2 check
Evening Dilwyn,
everything I do these days is open source. Help yourself, I'm pleased that my code is of use.
