Gold Card boots in monitor mode
i have installed tetroid's Gold Card in the QL .
On boot the screed with F1 Monitor / F2 TV is only flasehd on the screen and the QL automatically starts in monitor mode. There is no way to start it in TV mode.
As I use a SCART cable and a TV, in monitor mode i loose 2 character left and right.
Is there a way to start the Ql in TV mode ? Or to make it stop at the screen with F1/ F2 choice ?
probably I could write a boot program to redefine the windows, but I would prefer to have the F1/F2 choice when it starts
Re: Gold Card boots in monitor mode
It is probably set up with AUTO_TK2F1
You can disable this with AUTO_DIS or use AUTO_TK2F2 - see https://superbasic-manual.readthedocs.i ... auto-tk2f2
Thank you !
