Q- emulator and prospero fortran
mhanias
Brittle Membrane
Post by mhanias »
Had anyone manage to run prospero fortran with its eprom with image of its eprom?
It seems that after a point the emulator doesn't not recognise the rom image
Re: Q- emulator and prospero fortran
I tried, with no success, on QPC. The first compilation will apparently work, but the compilation seems to be writing to the EPROM area and messes up the ROM.
This is not the case with Prospero Pascal that uses the same ROM.
mhanias
Brittle Membrane
Post by mhanias »
Exactly the same happens with fortran Also in real QL with eprom 1.3 and the same happens
mhanias
Brittle Membrane
Post by mhanias »
mhanias wrote:Also in real QL with eprom 1.3 and the same happens
Are you really talking about "eprom in an EPROM"?. On a real QL, the code shouldn't be able to change EPROM contents. On QPC, I could observe the contents of the ROM memory area had changed after the first compilation run.
mhanias
Brittle Membrane
Post by mhanias »
A physical eprom with Prospero Fortran 1.3 but software is version 1.51
