Q68 - enable FAT16 driver
- Sparrowhawk
When not using the supplied SDHC card that comes with the Q68, how do I get the config menu program to run in order to enable the FAT16 driver?
a.k.a. Jean-Yves
Re: Q68 - enable FAT16 driver
There is a file called Q68_SMSQ.WIN on the SD Card, that is mapped to WIN8
Just
LRUN WIN8_BOOT
and the necessary tools will be loaded to configure SMSQ/E on that SD Card.
If the WIN8 mapping does not exist, then enter
WIN_DRIVE 8,1,"Q68_SMSQ.WIN"
This will map WIN8 to the file "Q68_SMSQ.WIN" on Card 1
Just
LRUN WIN8_BOOT
- Sparrowhawk
