QDOS For Amiga
- Giorgio Garabello
- Gold Card
QDOS For Amiga
Hello everyone, can you tell me if you can install SMSQE on the Amiga QL emulator?
thanks
Giorgio
thanks
Giorgio
Quantum Technology
Re: QDOS For Amiga
Hi Giorgio,
there is no software called "the Amiga QL emulator". So what do you mean?
If you mean Amiga-QDOS (also known as QDOS4amiga) or QDOS Classic, then not. As the names suggest, those are variants of QDOS.
- Giorgio Garabello
- Gold Card
Re: QDOS For Amiga
sorry: QDOS for Amiga..Peter wrote:Hi Giorgio,
ok, thanks
Quantum Technology
Re: QDOS For Amiga
Also sorry... I should have concluded that from the topic
By the way, QDOS Classic is more developed than Amiga-QDOS, probably the better choice, especially if you have a "higher" CPU.
As mentioned in the hardware topic "68060 based QL system" it would be interesting to know whether it runs on Amiga "Vampire" accelerator. If you use that accelerator, it would be nice if you could let us know.
- Giorgio Garabello
- Gold Card
Re: QDOS For Amiga
I'm almost tempted to do an experiment:Peter wrote:Also sorry... I should have concluded that from the topic![]()
take SMSQE_GOLD and run it on QDOS CLASSIC
Quantum Technology
Re: QDOS For Amiga
Save your time, that is completely hopeless. Amiga-QDOS and QDOS Classic do not emulate a QL and certainly not a QL with GoldCard. They are QDOS operating systems for the Amiga.
- Giorgio Garabello
- Gold Card
Re: QDOS For Amiga
Ah ... I did not understand this ... I thought they were emulators!Peter wrote:Save your time, that is completely hopeless. Amiga-QDOS and QDOS Classic do not emulate a QL and certainly not a QL with GoldCard. They are QDOS operating systems for the Amiga.
(On the Dilwyn Jones website he is described as an emulator ..)
(it's not me physically doing the tests but a friend of mine in the Quantum Technology group).
In any case do you think it is better QDOS Classic rather than QDOS4Amiga? ...
Why?
Giorgio
Quantum Technology
Re: QDOS For Amiga
I have an Amiga A600 which I have fitted a Vampire 2.
The Amiga lives on the floor under a chair at present, too busy to play with it.
I will get the Amiga out over the weekend and try out the Amiga QL Emulators to see if it runs on the Vampire 2.
Simon Goodwin, had it running on the A4000 withch had a 68060 card in, so maybe it stands a chance to run.
Just got to read the AmigaDOS manual.
Re: QDOS For Amiga
QDOS Classic is a JS ROM equivalent, with all machine dependant routines patched out.Giorgio Garabello wrote:Ah ... I did not understand this ... I thought they were emulators!
QDOS Classic is better, because it has a number of bug fixes, built-in exception handling, improved floating-point output routines, movable system variables, etc.Giorgio Garabello wrote:In any case do you think it is better QDOS Classic rather than QDOS4Amiga? ...
Why?
Also, it is available for Q40/Q60. (I even ported QDOS Classic to the Q68, but no time to release it yet.)
- Giorgio Garabello
- Gold Card
Re: QDOS For Amiga
However it is a pity that there is no SMSQE for amiga, given the large number of existing AMIGA machines ...Peter wrote:QDOS Classic is a JS ROM equivalent, with all machine dependant routines patched out.Giorgio Garabello wrote:Ah ... I did not understand this ... I thought they were emulators!
Why?
Quantum Technology
