Q-emuLator 3.2 for Windows
M68008
Post by M68008 »
A Q-emuLator update for Windows is available:
http://www.terdina.net/ql/winql.html
New features:
• Support for “mdump version 2” microdrive images
• Use the original Sinclair device driver to access microdrive images
• mdump_task now included in the FileUtil directory; Use it on a QL to create images of your microdrive cartridges (also works with any copy-protected software you own) that can be used with the emulator
• Accurate sound timbre
• Save QL screen snapshots to the desktop by pressing CTRL+F11
For more information about using the Sinclair device driver with microdrive images, see the blog post at http://qemulator.blogspot.com/2017/11/q ... ndows.html
simon629
Re: Q-emuLator 3.2 for Windows
Post by simon629 »
Hi when is the new Mac Version coming out
Outsoft
Post by Outsoft »
M68008 wrote:A Q-emuLator update for Windows is available:
New features:
Thanks to Daniele Terdina for programming, Massimo Raffaele for strong beta testing and Simone Voltolini for dumping more than 3000 md's :)))
3 years of hard work, enjoy!!!
M68008
Post by M68008 »
simon629 wrote:Hi when is the new Mac Version coming out
The plan is to port many of these features to the Mac version, but I don't know how long it will take.
Ooo excellent update, Q-Emulator is my main emulator. Looking forward to trying it :)
daniel_baum
Post by daniel_baum »
That's great! Thanks for all the hard work :)
I'll try it ASAP.
D.
Downloaded the update and installed on my Mint Linux laptop, all works very smoothly under Wine.
I also like the fact I did not have to re-register the emulator again.
Cristian
Post by Cristian »
Great job Daniele.
The emulator runs perfectly. It also maintained the previuos presets I prepared. Thanks!
daniel_baum
Seems to work very nicely; thanks Daniele:)
D.
Sparrowhawk
Post by Sparrowhawk »
Well, that's what you get for not visiting the forums in weeks (months?) - a lovely surprise like that! :D
I actually logged in to enquire about Q-emuLator for Mac, so I will post in a separate thread regarding that.
In the meantime, I shall dust off my Windows lapotp and install 3.this 2 updated version. Thanks!
a.k.a. Jean-Yves
