ZEsarUX 5.0
chernandezba
ZEsarUX 5.0
Post by chernandezba »
Hi!
ZEsarUX 5.0 is out! :)
You can download it from the URL:
https://sourceforge.net/projects/zesarux/
Finally I have succeded emulating Sinclair QL. I dedicated a lot of hours trying to guess how the keyboard work.
There is little documentation and I had to do lots of dissassemblies of the ROM and testing keyboard to know how it work...
So, hard work, this is a Quantum Leap, so this is a new major version, 5.0!
Complete changelog:
Added Sinclair QL emulation
Added remote command protocol. You can do enhanced debugging on ZEsarUX by using a telnet client.
There are a lot of commands, even many commands exclusive to this protocol and not found on the GUI, like:
* load-source-code
* hexdump-internal
* set-register
Added Easter Egg ;)
Added Specdrum emulation
Added RZX playback support
Added Multiface One, 128 and Three emulation
Added setting to write configuration file
Added menu item to reload IDE and MMC contents from file. You can now modify a used file outside the emulator and reload its contents
Added autosave snapshot at fixed interval
Added hardware debug port to output ascii characters or numbers directly on host console
Added two unused ports from the ZXI pool for some internal ZEsarUX features. See docs/zesarux_zxi_registers.txt
Added Hotswap from 128k to +2A, and +2A to 128k
Added File Viewer
Added support for drag&drop on Mac OS X, SDL2
Added support for OpenGL rendering on Mac OS X Cocoa driver
Added drawn piano for AY Piano menu setting (on all video drivers except text drivers)
Added Man Software GUI Style
Added setting to change DivIDE/DivMMC eprom firmware file
Added setting to allow writing to DivIDE/DivMMC eprom firmware
Added setting to disable autoframeskip
Added setting to set breakpoints from command line
Added setting to deny changing turbo mode when booting ZX-Uno and on bios
Added setting to disable beeper
Improved Debug CPU Window: now you can switch between different views:
1) 1 opcode, cpu registers, other internal registers
2) 9 opcodes, other internal registers
3) 15 opcodes
4) 9 hexdump lines, other internal registers
5) 15 hexdump lines
Fixed text to speech routine when sending non-ascii character
Fixed bug reading ULAplus register 64
Fixed bugs paging DivIDE/DivMMC
Fixed starting display row on ZX80/81/ACE, with border disabled and realvideo mode (was broken since 4.0)
Fixed reading from paging port on 128k and +2 machines: in this case, the same value read from the idle bus port is sent to the paging port
Fixed setting timings changing from Pentagon to non Pentagon machine
Fixed bug mapping real joystick buttons and axes with same number
Fixed bug when Jupiter Ace machine and border disabled
Updated Z88 OZ V4.7
Some other minor bugfixes and improvements
ZEsarUX
https://github.com/chernandezba/zesarux
Outsoft
Re: ZEsarUX 5.0
Post by Outsoft »
Great job!
We can read Floppy IMG and Microdrive MDV?
chernandezba
Re: ZEsarUX 5.0
Not yet. But you can load some games manually:
https://youtu.be/8ny0s6MEK2o
ZEsarUX
simon629
Re: ZEsarUX 5.0
Post by simon629 »
Can you RUN QDT/QLE or ICE Desktop and zpped QL Games on this Emulator OK thanks Simon Foster
Re: ZEsarUX 5.0
Ice should work - but QDT will not work as the emulator does not support the high colour mode required by QDT so far as I know.
It is still early days for ZEsarUX
chernandezba
Re: ZEsarUX 5.0
Yes, as Rich says, "it is still early days for ZEsarUX" ;)
I have first to add loading and saving data from microdrive and floppy and after that, all the rest...
It will be added if there's documentation of how it works
Cheers
Cesar
ZEsarUX
