Website
Website
I'm told my website is offline although some directories are directly accessible. I'm posting this from mobile phone as PC seems to have been damaged by a power cut in Storm Doris, along with my roof, so site probably won't be back up properly for some time.
- XorA
- Site Admin
Re: Website
Your top level index.html has gone missing, everything else seems fine.
Just sold my spare laptop though!
Re: Website
Ta. Will take a look when i get home later if power back on by then.
Re: Website
Back online now thanks to help from Rich Mellor, much appreciated.
Must get round to moving somewhere where the electricity doesn't go off every time there's a little puff of wind
Re: Website
Too wet and windy here Cristian, it'd rust and burn out (or is that what happened to me?)Cristian wrote:Or you could consider getting a good wind turbine
- XorA
- Site Admin
Re: Website
We better start a gofundme for Stainless Steel Dilwyn!dilwyn wrote:Too wet and windy here Cristian, it'd rust and burn out (or is that what happened to me?)Cristian wrote:Or you could consider getting a good wind turbine
But actually little known fact about wind turbines is they don't work in strong winds. And tend to suffer catastrphic failure when people try and use them in such.
Re: Website
Stainless Steel Dilwyn? SSD?? Ah, got it, XorA is offering to buy me a big SSD for my PC, thanks XorAXorA wrote:We better start a gofundme for Stainless Steel Dilwyn!dilwyn wrote:Too wet and windy here Cristian, it'd rust and burn out (or is that what happened to me?)Cristian wrote:Or you could consider getting a good wind turbine
Seriously though, thanks for all the emails of sympathy and advice, been a bit of a struggle last couple of days getting back up and running. Windoze repaired. Hardware seems OK, apart from a backup USB drive which insists on going to sleep all the time and Windows can't seem to wake it up when it's sleeping (it disappers from the list of drives when asleep) - any ideas anyone? Looked up on the interweb, seems an awfully common problem with no real solution. Bit embarrassing as that's my backup drive.
Re: Website
I had this issue too - it was the cheap USB caddy I was using - the power supply was just not reliable. Ended up switching to a more expensive SATA connected caddy which has been fine ever since (apart from the SATA cable sometimes falls out the back of my PC - there is no spring mechanism or anything on them to give a good grip!dilwyn wrote:
Re: Website
Tell us the truth: you're a C5 userdilwyn wrote:Too wet and windy here Cristian, it'd rust and burn out (or is that what happened to me?)
