DataDESIGN API
genetika
DataDESIGN API
Post by genetika »
Hi.
Where do I can found the Prowess DataDESIGN SuperBASIC API.
I found only the API manual.
Thanks in advance. :D
G.
Re: DataDESIGN API
I had to look when you asked - but it is on the Sinclair QL Homepage: http://www.dilwyn.me.uk/database/index.html
Look for DdesApi.zip under DataDesign.
This includes a PDF of teh API programming manual - the description of the commands starts on page 16. Each command has the information for use from SuperBASIC and from Assembler.
Was it something else you are looking for?
genetika
Re: DataDESIGN API
Post by genetika »
Hi.
What do I need to use the DataDesign API ?
What do I need to load to activate the API Library ??
Is
LRESPR flp1_engine_rext
the correct command to activate the API library?
Thanks!
M.
Re: DataDESIGN API
I am not sure - it has been many years since I looked at this!
swensont
Re: DataDESIGN API
Post by swensont »
The user manual for DataDesign is here: http://www.dilwyn.me.uk/database/DATAdesign.pdf
It has the information about installation and using the database.
Tim Swenson
