Hi I'm trying to install qdos-gcc on a Ubuntu 16.04 but the gcc4 installed generate error.
There's a right distro to use? Probably the old one with old gcc installed?
Does exist a VmWare distro Linux ready to use?
Inviato dal mio iPhone utilizzando Tapatalk
Right distro Linux to use qdos-gcc
Re: Right distro Linux to use qdos-gcc
You need to build `gdos-gcc' from sources. I am going to push my clone to GitHUB as well.
Meanwhile you may follow here>>>
http://theqlforum.com/viewtopic.php?f=3& ... c&start=10
Tomas
Tomas
Hi tomas I've read the post but it's not clear what distribution you use.
Debian 4? Redhat 7?
Thanks to put on Git your version!
Debian 4? Redhat 7?
I am sorry for a long delay.
I realised, you may also find `qdos-gcc' at Dilwyn's site under,
http://www.dilwyn.me.uk/c/index.html
It should compile under any distribution, you need development tools installed (gcc, cpp, make, etc).
Hope this helps.
Tomas
Hope this helps.
Tomas
