QL/E - The QL Environment (QLE)
QLvsJAGUAR
Post by QLvsJAGUAR »
Fri Dec 29, 2023 6:29 pm
Latest version 3.23 (Codename "Midnight Sun", 2023 edition) is out now!
Details about QL/E, Download & More as usual on the sinclairql.net website, link see message footer.
Fri Nov 04, 2016 2:01 pm: Version 3.15 is out now. Get it from the link in the message footer. QL forever! Cheers, Urs
QL forever!
QLvsJAGUAR
Re: QL/E
My post was rather short because I had just finished (much later than hoped and planned) and had to leave home towards Germany (arrived in the hotel minutes ago after a 580km journey) where I will attend the ejagfest (an ATARI event, very similar to the QL shows. With the only difference that instead of Sinclair machines and derivates it's all ATARI related).
http://ejagfest.de/
Main change in QL/E is that it comes with brandnew SMSQ/E and SMSQmulator versions (September/October 2016) from Wolfgang Lenerz plus very latest IPNet from Martin Head. And support for the various QL compatible platforms has been improved.
See the testbench I was using to complete the new version.
QL/E v3.15 on Urs' TestBench (Windows 7 with QPC2, SMSQmulator and QemuLator/Minerva; Windows 10 with QPC2, MIST/QLcore/Minerva with QL-SD)
QL forever!
QLvsJAGUAR
Re: QL/E
I forgot, there’s one more Thing...
QL/E can now be fully and easy be configured. After startup of the boot program, during the countdown, simply press ESC (or use the brute force method CTRL+SPACE to BREAK). Then simply enter QLECFG (followed the <ENTER> key) and you have 16 topics to configure in a query/answer type setup. After saving just reboot and here we go. In case you do not like your configuration, you can delete the file QLE_cfg_inf (on WIN1_ or SDC1_ depending of your system) at any time and - after a fresh boot – the default configuration is back. Easy, isn’t it?
QL forever!
Outsoft
Re: QL/E
Post by Outsoft »
QLvsJAGUAR wrote:My post was rather short because I had just finished (much later than hoped and planned) and had to leave home towards Germany (arrived in the hotel minutes ago after a 580km journey) where I will attend the ejagfest (an ATARI event, very similar to the QL shows. With the only difference that instead of Sinclair machines and derivates it's all ATARI related).
http://ejagfest.de/
Good job!
QLvsJAGUAR
Re: QL/E
I’m back from Germany where after the great ATARI weekend - see my posts in the Google+ blog (link in the message footer) - I attended a Retail Technology Event for my professional live. Will be busy the coming days with both work and life, not much time for the QL. But there was this minute yesterday evening when I fired QL/E on my sons PC and gave 4 instances of QPC2 a go, communicating with each other through Martin Head’s LocalNet.
4 instances of QPC2, communicating with each other through Martin Head’s LocalNet.
QL forever!
QLvsJAGUAR
Re: QL/E
QL/E v3.15 runs nicely under uQLx 2017, even in standard QL resolution and with JS ROM.
All one has to do is to replace the uqlx.win file with a renamed (to uqlx.win) copy of QLE.win.
Thanks to Graeme, Timothy, Rob and volunteers for bringing uQLx back!
QL forever!
uQLx 2017 starting QL/E v3.15.
uQLx 2017 running QL/E v3.15.
QL forever!
Re: QL/E
QLvsJAGUAR wrote: All one has to do is to replace the uqlx.win file with a renamed (to uqlx.win) copy of QLE.win.
Or just edit the config file ;-)
QLvsJAGUAR
Re: QL/E
The next update of QL/E is in the making, but already quite a bit behind my original schedule. The number of SMSQmulator and SMSQ/E updates plus the release of uQLx 2017 hit me. Here's a sneak peek of new desktop wallpapers. This time snow birds.
More birds for QL/E...
QL forever!
QLvsJAGUAR
Re: QL/E
Version 3.16 (Codename "Snow white swan", Edition 1702, last updated 28.02.2017) is out now!
More info and download using the link in the message footer.
QL forever!
Cheers, Urs
QL forever!
QLvsJAGUAR
Re: QL/E
This is how QL/E v3.16 looks when running under SMSQmulator.
SMSQmulator v2.23 has TCP/IP socket support, supporting the web browser lynx!
QL forever!
