Hello, I need help.
I'm trying to run the mail client "qpop3". of QPC2
I downloaded, copied in its folder, properly set the environment variable but the program does not start even, closes without any message.
Surely I'm wrong or I forgot something but not sure what.
Gio
QPOP3 help!
- Giorgio Garabello
- Gold Card
- Giorgio Garabello
- Gold Card
Re: QPOP3 help!
Sometimes, the QL Forum needs a bit of patience
Didn't run here as well. One of the problems is, if the program tries to write an error message to the console, it realizes it has been compiled without console support....
I have just re-compiled it, now it runs for me (as I don't have any non-encrypting POP-server handy, I couldn't really verify that it works, but for me it runs....)
See attachment (rename qpop3_zip.pdf to qpop3_zip, then unzip on QPC).
- qpop3_zip.zip
- (126.83 KiB) Downloaded 151 times
- Giorgio Garabello
- Gold Card
Re: QPOP3 help!
tofro wrote:Sometimes, the QL Forum needs a bit of patience
but the program start?
Quantum Technology
Re: QPOP3 help!
Yes. But only after a re-compile. The one I downloaded from Jonathan Hudson's site i had the same problems you experienced.Giorgio Garabello wrote: but the program start?
- Giorgio Garabello
- Gold Card
Re: QPOP3 help!
tofro wrote:Yes. But only after a re-compile. The one I downloaded from Jonathan Hudson's site i had the same problems you experienced.Giorgio Garabello wrote: but the program start?
Now works!
thanks
Quantum Technology
