QL-SD Prototype @50GBP
Sell your QL items here!
Paul
Post by Paul »
I have listed five prototypes at a reduced price.
They are fully working with the new SD Card holder.
The LED was positioned too much left, so I had to bend it to the right. This way its lying over the SD-Slot instead of next to this. I have ordered a new batch of PCBs where the LED will be right of the SD-Slot.
This will then be available at the normal price.
This Protype is well suited for people who don't care about the position of the LED and for those who will solder a piece of wire and use the original microdrive LED instead of the on board LED.
Kind Regards
Paul
SM7I
Re: QL-SD Prototype @50GBP
Post by SM7I »
Where to get it ? I want one !
Paul
Post by Paul »
SM7I wrote:Where to get it ? I want one !
http://www.sellmyretro.com/offer/details/4257 8-)
SM7I
Post by SM7I »
Can see it on site, but not buy ?!? Says listing is closed. Help !!
Paul
Post by Paul »
Just retry, I have relisted them. Only three left.
The very last original and two prototypes.
Need to buy stuff for making new ones.....
New PCB's for regular production are here already...
Outsoft
Post by Outsoft »
Paul wrote:Just retry, I have relisted them. Only three left.
I've seen this QL-SD and I would like to buy it one.
But I read that doesn't work on GC and SGC: can work with Trump Card?
Thanks a lot.
Best regards.
Paul
Post by Paul »
Thanks a lot.
Best regards.
Yes, QL-SD does fit the Trump Cards very good.
I used mine with a trump card and it was brilliant :)
Outsoft
Post by Outsoft »
Very interesting, thanks.
So is not compatibile only with GC and SGC.
If I can ask, why? ;)
I would like to use SMSQ/E on it but It will work only on GC and SGC.
Thanks.
P.s.: Hi Van, I'm Outsoft on IRC ;)
