Toolkit
Mr_Navigator
QL Fanatic
Toolkit
Post by Mr_Navigator »
Does anyone have the manual for the original QJUMP toolkit or super toolkit, this is missing from the QL SPG's work and we would like to put this one to bed, so to speak
Re: Toolkit
Lee,
I guess you're not referring to Toolkit II, as there's lots of manuals around for that. I have found a reference to the Toolkit that was included in the PCML disk interface which I suppose would be the "original" Toolkit 1 here:
http://www.sinclair.hu/speccyalista/kon ... t_v007.pdf
Hope this helps,
Mr_Navigator
QL Fanatic
Re: Toolkit
tofro wrote:Lee,
Hope this helps,
Many thanks Tobias 8-)
Re: Toolkit
The manuals are on Dilwyn's web site, in PDF or epub formats.
Mr_Navigator
QL Fanatic
Re: Toolkit
Derek_Stewart wrote:Hi,
Hi Derek, I can only find Toolkit II manuals not Toolkit.
Incidentally the PCML document that Tofro pointed me to is on Dilwyn's site and one I re-wrote in Word Document form :oops:
However if anyone knows or has the original documentation to the original Toolkit software, we would appreciate a copy.
Regards Lee
Silvester
Re: Toolkit
Post by Silvester »
I have made a scan of the documentation I received with a SuperToolkit EPROM complete with an EPROM caddy from CARE electronics in 1985. It is 24 loose leaf pages meant to be put in QL user guide. Most of what it contains has been covered in later documents already reproduced on Dilwyn's website.
The EPROM is labelled SuperToolkit and the documentation refers to it as SuperToolkit (not tk2), but the eprom banner is v2.08
The pages are laid out better than scanned stuff and it contains illustrated cover. File size is 4.7Mb
PM your email address if you would like a copy.
David
Re: Toolkit
The SuperToolkit and Toolkit II are exactly the same
The original QL Toklit manual is only A5 and whilst in a loose leaf folder would probably not be easy to scan.
Re: Toolkit
All,
I very much doubt the original Toolkit (1) was sold for a long time. It used to be advertised by Sinclair only for half a year or so after the first machines were out. (Apparently the breakup between TT & Sinclair ended this deal.)
I do think, however, that Toolkit 1 was just a sub-set of what was later called Toolkit 2, so the manuals should be usable for both (just with quite a number of commands not present in TK1). That's why I thought the TK that was built into the PCML disk interface could have been TK 1 (early enough, sub-set of TK2 only).
Other than for preservation purposes and maybe collector's value I don't see much point in having it. I do understand, however, the point of "complete is complete".
Re: Toolkit
We have preserved Toolkit 1 - just not the manual - I was surprised to find that it was lots of different files and routines rather than just the one machine code extension, so the manual definitely needs scanning!
Re: Toolkit
Oh. Interesting.
Can you please elaborate a bit on what was actually included with the original toolkit?
Thanks
