Monitor Connection?
Andi B.
Monitor Connection?
Post by Andi B. »
Hello all,
in the eighties my brothe and I had a cool black color monitor (Prism?) for our QL but now 25 years later I'm looking for an alternative to connect the QL to a modern VGA screen.
Unfortunately we have sold everything when we bought an Amiga decades ago... :(
Has anybody any ideas for a guy without deeper knowledge but a soldering gun (maybe using a CGA/EGA/YUV TO VGA converter from the Bay)?
Which possibilities are there to convert the QL video output to any kind of usable signal?
Thank you!
Regards
Andi B.
belg4rion67
Re: Monitor Connection?
Post by belg4rion67 »
Hi dear, I'm Paolo from Italy and in my country there's a web seller that has a cheap videoconverter: view at this link: http://shop.gruppoarea.info/elettronica ... s_id=19319
is only for composite but works fine on my Speccy; for my QL I'm using a Samsung LCD monitor/tv connected via Scart and even this works very well (even if only with QL in tv mode)
Only original hardware! :)
http://www.theqlforum.com/viewtopic.php?f=2&t=12
That thread should be just the job for you!
polka
Post by polka »
As I stated in my introduction, I did myself a simple QL to SCART cable that I use now with my flat screen LCD TV and indeed get 512x256 resolution very well. Tomorrow I will open it to remember what is inside and tell you...
Paul
May the FORTH be with you !
POLKa
Andi B.
Post by Andi B. »
Now i prepared a Scart cable (while waiting for my VGA-converter for the monitor).
Unfotunately does the TV shows nothing when directly connected and using a videorecorder as a kind of adapter the TV shows an colored image but it moves fast from right to left and a little bit from bottom to top.
Any ideas how/if this can be fixed?
Greetings from Munich
Andi
Regards
Andi B.
belg4rion67
Hi, for my QL I have made a scart cable like this: http://www.fruitcake.plus.com/Sinclair/ ... ableQL.htm
All resistor enter in scart shell wothout problem because are all 1/4 watt power and on my previous TV set (an old analog Philips system) images was fine, with my new Samsung TV/monitor works very fine :D
Andi B.
Post by Andi B. »
Andi B. wrote:... I had a cool black color monitor (Prism?) for our QL but now 25 years later I'm looking for an alternative to connect the QL to a modern VGA screen.
What a coincidence that last week I could buy the same model PRISM QL 14 monitor we had in the good old days... :D
It was offered on ebay as defect and I got it for 1,- EUR (+ shipping). In fact the circuit board has a crack but I could solder the broken conducting paths...now it works!
But one little thing is not 100% perfect: There are vertical dark stripes visible on the left side (see pictures). Does anybody know, why this occures and how this can be fixed?
Regards
Andi B.
I wonder if that is a degaussing issue? :?:
Nope.
That's a ring/bounce issue. There are so many causes, from poor quality lead with no ferrite cores on it, to capacitor issues to....
I suspect putting a couple of ferrite cores one on each end of the cable could help some to get a cleaner signal into the monitor.
