What is Best?
Mr_Navigator
QL Fanatic
What is Best?
Post by Mr_Navigator »
I currently have an old XP based laptop, not doing much and slowed to a snails pace even with a fresh install.
So, I have installed LUBUNTU as it is a light install, Laptop runs fast and fine
Installed QPC2 using Wine
Installed SMSQemulator also
I now want to include links to websites and other programs (possibly) as icons and make this a QL based only laptop.
So I have started with the following list and I know this maybe a personal thing but are there any others I should include or have missed. I am looking at a maximum of about 24 links including software.
in no particular order
Dilwyns site
RWAP software
Sell MY Retro
qlis30.org.uk
http://www.theqlforum.com/
quanta
Sinclair QL Preservation Project
Sinclair QL Computer Wiki
The Sinclair QL and QDOS compatible systems site
SMSQemulator
QPC2
JMS
quo vadis design
Sandy
any others?????
btw has anyone seen this http://sinclair-uk.weebly.com/sinclair-os.html
Re: What is Best?
I have an old P3 laptop that I keep a small xp install on and use only with qemulator. Once you start chucking the internet at it you are in trouble, so I don't bother with it on there :)
Re: What is Best?
You should remove Sandy. I am still regrouping from the financial defeat there.
I'm quietly assembling Auroras in the background, but nothing else is happening for a while.
Mr_Navigator
QL Fanatic
Re: What is Best?
Dave wrote:You should remove Sandy. I am still regrouping from the financial defeat there.
Ok Dave didn't want you thinking I left you out :)
Mr_Navigator
QL Fanatic
Re: What is Best?
vanpeebles wrote:I have an old P3 laptop that I keep a small xp install on and use only with qemulator. Once you start chucking the internet at it you are in trouble, so I don't bother with it on there :)
I had the same experience with XP but LUBUNTU works really well at the moment 8-)
belg4rion67
Re: What is Best?
Post by belg4rion67 »
http://www.terdina.net/ql/q-emulator.html
The Daniele's site of q-emulator ☺
Only original hardware! :)
