QL monitor....
prime
QL monitor....
Post by prime »
Hi all,
Is there a machine code monitor available for the QL, I'll need to be able to single step code set breakpoints etc. I've seen references to QMON2, but understand this is still commercial, is it still available anywhere ?
Cheers.
Phill.
EmmBee
Re: QL monitor....
Post by EmmBee »
Hi Phill,
How about using Q-emuLator? I'ts free. You start the m/c debugger by pressing F11. I've never actually used this, but going from the documentation, it would appear that it could easily do all the things you want it to do.
Michael
Re: QL monitor....
There is the Talent, Assembler Workbench. Available to Quanta members.
Re: QL monitor....
Why not look on Dilwyn's web site in the Assembler Tools section or with this link:
http://www.dilwyn.me.uk/asm/index.html
Computer One Monitor may suit your needs.
Re: QL monitor....
Derek_Stewart wrote:Hi,
Can only second that. C1M is by far the best MC monitor for the QL, IMHO. Even better than QMON2, especially for debugging executable jobs. It has a concept of a "Base pointer" - That is, the load address of your code. This means you don't need to fiddle around with address offsets when comparing a paper listing to Monitor output.
prime
Re: QL monitor....
Post by prime »
Thanks for the suggestions guys, I would normally use the debugger in MESS to single step the code but as this is hardware related (and hardware not emulated by MESS :( ), it needs to be done on a real machine.
I have after all these years taken the plunge and signed up for QUANTA and will try some of the software in the library.
tofro wrote: Can only second that. C1M is by far the best MC monitor for the QL, IMHO. Even better than QMON2, especially for debugging executable jobs. It has a concept of a "Base pointer" - That is, the load address of your code. This means you don't need to fiddle around with address offsets when comparing a paper listing to Monitor output.
I downloaded the C1M, as i used to use the C1 Assembler / Linker back in the day, and it looks promising, but the base pointer thing (may) get in the way of debugging ROM code, especially if it's in the $c000 area, the readme does say there is a way of forcing an absolute address but, it seems to suggest accent-u (ú) as a suffix, I tried that but got an error....
Cheers.
Phill.
Re: QL monitor....
If bp annoys you, simply set it to 0, and all your addresses are absolute
.bp 0
prime
Re: QL monitor....
Post by prime »
tofro wrote:If bp annoys you, simply set it to 0, and all your addresses are absolute
.bp 0
Ahhh, thanks that should do the trick.
Phill.
prime
Re: QL monitor....
Post by prime »
Incase anyone else is looking for the C1M docs, they are available here :
http://sinclairql.speccy.org/archivo/do ... tor_c1.pdf
In PDF format.
They where linked from : http://sinclairql.speccy.org/archivo/docs/docs.htm
Cheers.
Phill.
