I have now managed to acquire a suite of the TDI programs - there are some large manuals on UCSD Pascal, USCD Fortran, Applications Development Reference and a QL introductory booklet, along with the following microdrive cartridges:
From the TDI USCD Pascal
PASCAL P-System PASCAL (Pascal Compiler, Filer and Editor)
PASCAL P-System PBOOT (Pascal Bootstrap)
PASCAL P-System ASM (Assembler, Linker, Utilities) ** THIS IS CORRUPT **
From the Advanced Development Toolkit
P-System ADTK1 (Development Utilities)
P-System ADTK2 (Interface Units, Turtlegraphics)
From the TDI UCSD Fortran-77
FORTRAN P-System ASM (Assembler, Linker, Utilities)
FORTRAN P-System FMISC (Fortran Configuration Options) ** THIS IS CORRUPT **
Not sure what package this belongs to...
P-System SOURCES (Driver Sources)
This does at least go a long way to preserving this rare range of compilers - although the manuals are in the form of books, which would be a real pain to scan in.
I have not had chance to try any of this out - it does not help that most of the files are contained within a single container (pSystem) on each cartridge - however, I would guess that the Fortran ASM might well be the same as the PASCAL version - who knows...
Does anyone have any more information / copies of any of this?
TDI Software pSystem - Fortran & Pascal
Re: TDI Software pSystem - Fortran & Pascal
OK, looking through the QL Owners Handbook for this, I can see I am missing some microdrive cartridges:
From the UCSD Pascal:
- PMISC
From the UCSD Fortran
- FBOOT
The P-System SOURCES (Driver Sources) cartridge is part of the Advanced Development Toolkit...
- PMISC
- FBOOT
Rich,
as UCSD Pascal used to be conceptually the same thing as Java is today (an implementation of a programming system on a virtualized machine with platform-independent binaries and file system) it should theoretically be possible to re-construct the missing material from the platform-independent sources (as long as the QL virtual machine is intact and of the right version).
There is a lot of information around on UCSD-Pascal (the sources are free today) that could be used by someone interested to rebuild everything.
One place to start could be http://pascal.hansotten.com/index.php?page=more-files
According to my present knowledges, the p-code should be the 8080 machine code.tofro wrote:UCSD Pascal used to be conceptually the same thing as Java is today (an implementation of a programming system on a virtualized machine with platform-independent binaries and file system)
Dex,dex wrote: According to my present knowledges, the p-code should be the 8080 machine code.
actually it isn't - It's a stack-based machine without any significant registers (except PC, stack and some stack frame pointer registers). Very Close to Forth in some aspects.
This one http://ucsd-psystem-fs.sourceforge.net/
might probably be of interest - It allows mounting a p-System disk Image on Linux. Would be interesting to know if that works with the TDI Image files......
I managed to salvage most of these microdrive cartridges, but I am sill missing some physical cartridges:
PASCAL ASM (I assume this is probably the same as the Fortran version)
PASCAL PMISC
As for reading the programs - I am still missing quite a lot as the cartridges were mainly unreadable.
PASCAL PMISC
