Breaking news: The QIMSI Interface
- janbredenbeek
Re: Breaking news: The QIMSI Interface
The Minerva keyboard driver including source is now available on my GitHub repository: https://github.com/janbredenbeek/QIMSI-KBD
Jan
Jan
- Trump Card
Peter,
Do you see any problem using your QIMSI Interface with a Aurora board (assuming the correct ROM interface converter) ?
Francois
Francois
Many thanks Jan! Fantastic job!janbredenbeek wrote: Mon Oct 09, 2023 4:40 pm The Minerva keyboard driver including source is now available on my GitHub repository: https://github.com/janbredenbeek/QIMSI-KBD
There is a small mistake in the description, however. You write "QIMSI has a micro-USB keyboard connector, but currently only accepts pure PS/2 keyboards". This is not correct. QIMSI does of course work with PS/2-USB combo keyboards! Which is also the more intended kind of keyboard for QIMSI. It does not require a PS/2 to USB converter then. I tried to make that a little clearer in the manual.
I can recommend the KeySonic mini keyboard ACK-595C+ for example. Available from Amazon, Reichelt, etc.
Hi Jan,janbredenbeek wrote: Mon Oct 09, 2023 4:40 pm The Minerva keyboard driver including source is now available on my GitHub repository: https://github.com/janbredenbeek/QIMSI-KBD
Jan
Does the PS/2 keyboard and the QL keyboard work together?
If so maybe a numeric pad can be added to the QL.
I think it is quite clear that one has to switch the active keyboard by BASIC commands.Derek_Stewart wrote: Mon Oct 09, 2023 9:37 pm Does the PS/2 keyboard and the QL keyboard work together?
- janbredenbeek
Oops, sorry... Corrected that section.Peter wrote: Mon Oct 09, 2023 6:45 pm Many thanks Jan! Fantastic job!
Note that it also has been forked to the SinclairQL repositories on GitHub.
By the way: Since QIMSI has been released now, will the new SMSQ/E version 3.39 with QIMSI support be released too? Wolfgang's site still shows 3.38.
Jan
Last edited by janbredenbeek on Mon Oct 09, 2023 10:48 pm, edited 1 time in total.
- janbredenbeek
Unfortunately not, since there can only be one keyboard decoding routine active at a time under Minerva.Derek_Stewart wrote: Mon Oct 09, 2023 9:37 pm Does the PS/2 keyboard and the QL keyboard work together?
(as I wrote earlier, the first build contained a bug that caused both keyboards to be active, and typing on the PS/2 keyboard resulted in characters being entered that not even remotely resembled the keys pressed).
What I'm not 100% sure about is the electrical behaviour with all possible backplanes, especially large ones, as I have no opportunity to test.FrancoisLanciault wrote: Mon Oct 09, 2023 6:45 pm Do you see any problem using your QIMSI Interface with a Aurora board (assuming the correct ROM interface converter) ?
But with Aurora itself, I see no problem at all. Just make sure the address range $C000 ... $FFFF is not occupied by a different device.
Many thanks! Awesome achievement.
I didn't expect the external keyboard feature to become very popular, but with your driver, it's a different story.
Yes. Wolfgang told me he needs some more time, so the other release targets also get ready.janbredenbeek wrote: Mon Oct 09, 2023 10:30 pm By the way: Since QIMSI has been released now, will the new SMSQ/E version 3.39 with QIMSI support be released too? Wolfgang's site still shows 3.38.
Hi Peter.
First of all let me say thank for this great add on (just ordered one to Stephan
). I have two questions:
Is the QIMSI compatible whit qubide + hard disk (or DOM)?
Is the QIMSI compatible with Marcel QL-SD?
Thank you for your answer, your time and your great work.
Ciao.
Marco
Ciao.
Marco
