Just spotted these on sellmyretro, might be useful for someone?
HelloQLObi wrote:Hi Peter,
i am still surprised that you need addtional hardware to use a virtual floppy. Just buy a GOTEK Floppy emulator, jumper it as drive A and connect to your floppy controller. Shown on the 30th Ql user meeting by me.
You have than 100 disks to fill with data. Only buy the version which has this 2 Digits (99 drives), the versions with 999 floppies doesn't allow formating the disks with the help of the QL.
Look carefully for your needs: a 720k or the 1.44mb Version. Both working fine, but have differnent firmware.
QLobi
Please can you let me know where you found the two digit (99) drives on EBay for £12.50?Derek_Stewart wrote:Hi,
The Gotek drives are availble for £12.50 ish... on eBay.
The drives can be Flashed for Amiga and HXC emulation, which is extra.
Did you alter the driver code on the Gotek or using it straight out of the box.
I have a Gotek waiting to be installed in a QL or Q60
But on saying this, the native Gotek will work with the QL disk images, I have this on the list of job to do.The following elements allow you to program the low cost Gotek USB Floppy Emulator with the HxC bootloader & Firmwares. Contact Jean-François DEL NERO at (http://hxc2001.free.fr/imiel.htm) to get an account on the update server.
I have had a look at the 2 x Gotek drives 3 digit display, I think they are 720K Models. One is flashed to work with Amiga Disks and the other is a standard Gotek drive.http://www.ebay.co.uk/itm/3-5-1-44MB-US ... Sw14xWJLlJ
http://www.ebay.co.uk/itm/3-5-1-44MB-US ... SwR0JUSjVJ
http://www.ebay.co.uk/itm/720K-Floppy-3 ... SwyvBV9m0X
Does it have to be the 720k or 1.44MB model?
Thank you for your reply Derek and your help. I would need a 720kb Gotek 2 Digit Drive then. The only 720kb Gotek drive I have found seems to be a 3 digit 999 disk model which has been stated will not work.Derek_Stewart wrote:Hi,
But I think the model selection will be based on your disk interface.
The only QL Disk Interface that can handle 1.44Mb HD Disks is a Super Gold Card or Gold Card. Interfaces like Trump Card, SuperQboard etc... have 720Kb DD Disk handling only.
The 720K Gotek can be connected to either a Gold Card, Trump Card or other older disk interfaces, but the 1.4Mb GOtek can only be connected to the Gold Card or Super Gold Card.
Extra hardware is needed for the flashing to HxC, but it works without it.
I will get the Gotek running over the weekend and report back.
